Industrial Communications
(Reference#1433074) Using Configurator II to set up Profi bus communication with Siemens CPU S7 314 2dp
I'm trying to connect to Siemens CPU S7 314 2dp with the Comsoft Configurator II.
I set up up the DF profi II (PCIe card) as master (address 10) and the Cpu 314 as slave (address 2).
Baud rate is for both devices 1500 kb/sec.
I download configuratoin to DF Profi II and get "download complete" response and everhing is looking OK.
The green LED on the DF Profi II has a steady light.
When I push "Monitor / Modify Connect" the green, yellow and red LEDs all have steady light.
Also the square around slave-module CPU 314 is red in Configurator II.
When I look in the diagnostic I get this message:
"(2) CPU 314-2C DP not OK!
Bit 1.0: Station_Not_Existent"
There are several other modules on bus...
Do I need to dowload GSD-files for these as well?
Also the CPU 314 is configured as master...
But as far as I can see I can't put the CPU314 as master in the bus configuration...?
What could be wrong?
Message 1 of 1
(5,528 Views)
