Industrial Communications
Runtime device allocation with EtherCat in LabVIEW
We are looking at the possibility of using EtherCat to communicate with a chain of MFCs and sensors in a system. However, our system comes in many variants with some having more devices than others. Is there any way with the LabVIEW implementation of EtherCat to dynamically build up the chain of devices? Looking at the documentation it seems like all devices have to be defined in the project which I don't believe will work for us as we don't want to built a separate executable for every variation. Thanks.
Message 1 of 8
(6,270 Views)
When you mention "build up the chain of devices", do you mean to auto-discover and auto-configure all EtherCAT slaves? If so, NI EtherCAT provides programmatical methods. You can see the details in this KB.  You can find some example code here.
Thanks!
Message 2 of 8
(6,224 Views)
Will this API work with non-NI EtherCAT slaves?
Thanks.
Message 3 of 8
(6,196 Views)
Yep, non-NI EtherCAT slaves support is mentioned in the KB:
Message 4 of 8
(6,187 Views)
I did this successfully with a number of Beckhoff EP series slaves. One odd  thing though is that the Device Name that the scan engine gives each device does not follow the EtherCat address. What I mean by that is that instead of EtherCat devices names for addresses 0,1,2,3.... are not necessarily "Device1", "Device2", "Device3", "Device4". Some are out of order with respect to address.
To be able to dynamically access item thru scan engine, it would be very helpful if you KNEW that Device7 always corresponded to address 6, for example.
What is going on there?
Message 5 of 8
(5,145 Views)
Hi MarkCG,
Do you mean that you saw the name of Device1 if the slave address is 0?
Thanks!
Message 6 of 8
(5,082 Views)
No, Device number out of order with address number on some slaves.
Message 7 of 8
(5,058 Views)
Hi MarkCG,
We did not see this phenomenon before. Is there any error? Could you take a snapshot of which slave is the wrong number?
Thanks!
Message 8 of 8
(5,033 Views)
