Industrial Communications
Sistema escaner superficial de dispositivos electrónicos
Hi
I'm searching a scaner system for electronic devices. The system needs to identify a device for his external appearence.
(4,375 Views)
Hi RVelandia2015,
There are several variables to analyze in this case. If you are just starting wtih your application setup, I have found the following example which uses the NI Vision Development Module to identify a custom patern and search it in other images. Hope you may find it helpful.
http://www.ni.com/example/30594/en/
Sil.VI
(4,358 Views)
