02-19-2015 10:06 AM
Hi
I'm searching a scaner system for electronic devices. The system needs to identify a device for his external appearence.
02-20-2015 11:58 AM
Hi RVelandia2015,
There are several variables to analyze in this case. If you are just starting wtih your application setup, I have found the following example which uses the NI Vision Development Module to identify a custom patern and search it in other images. Hope you may find it helpful.
http://www.ni.com/example/30594/en/
