Industrial Communications
Test PROFIBUS
Hi
We are using cRIO PROFIBUS Slave to communicate with DCS, I want to test and validate my results from cRIO to DCS using some emulator before the cRIO setup is installed on site.
Newbie with PROFIBUS, need help
Thanks in advance.
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
Message 1 of 1
(6,469 Views)
