Industrial Communications
Unable to connect NI OPC server to ATV320 Modbus
I am trying to connect my MODBUS TCP/IP (Variable frequency motor control) to a NI OPC server to establish remote motor control using OPC client. However, I am not able to connect my OPC server with my MODBUS. The issue is that namespace or the variable instance created using the MODBUS I/O address shows bad quality or no connection established on NI Quick client. Here I have attached the procedures that I followed to connect to MODBUS. Please let me know if you need any details from my side.
Note: I tried the below steps using both the slave and master ethernet port on the MODBUS.
MODBUS details:
Make: Schneider ATV320
Address logic list: Schneider Electric_ATV320_communication_parameters  provided by Schneider
Ethernet Module: VW3A3616
IP Address: 192.168.10.1
Subnet mask: 255.255.255.0
IP Address PC network port: 192.168.10.1
Subnet mask PC network port: 255.255.255.0
Message 1 of 1
(1,441 Views)
