Industrial Communications
cRIO Profibus - Driver doesn't install completely..
Hi everyone,
i have a NI cRIO 9039 and LabVIEW 2016. The system is equipped with NI RIO 16, LV Real-Time 16, NI-VISA 16 and my laptop mounts Windoes 10.
Now, i have already installed the driver version 2.0.3 and 2.0.5 trying compatibility mode for windows XP, windows Vista, Windows 7 but i cannot get a proper installation of the driver.. everything i get is the folder cRIO PB with the GSD file. The "setup.exe" doesn't seem to install the examples VIs, the libraries, ecc... and, of course, the cRIO doesn't recognize the profibus module (that is the slave version)...
What can i try?
Thanks in advance..
Mattia
Message 1 of 8
(5,622 Views)
Accepted by Mattia88
Nevermind, i solved the problem by using driver version 2.0.7 that i have somehow found on internet..
Message 2 of 8
(5,579 Views)
I'm glad to hear that you solved your issue,
Please mark the post as solved.
Bye
Steeb
Message 3 of 8
(5,547 Views)
Hi Mattia88,
I am in the almost same issue.
I try to use PROFIBUS Master/slave module with cRIO-9039.
My environment is LabVIEW2016, cRIO-16.0, and  NI-VISA 16.0, but OS is Windows 7.
Any configurator II and III in the NI-PROFIBUS for cRIO driver version 1.1.10, 2.0.3, and 2.0.5 cannot recognize my profibus module in cRIO-9039.
Where did you get the NI-PROFIBUS for cRIO driver version 2.0.7?
I can find up to 2.0.5 in the following link but I cannot find version 2.0.7.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/sn/ssnav:ndr/q/NI-PROFIBUS%20...
I would appreciate any information you could provide me!
dotriaconta
Message 4 of 8
(5,351 Views)
I've found those drivers inside this repository:
http://www.mmnt.net/db/0/0/ftp.ni.com
Message 5 of 8
(5,336 Views)
Thank you for your information.
Unfortunately, I cannot find any Profibus driver in that NI's FTP link.
According to you, the driver version 2.0.7 is necessary to use the PROFIBUS module in cRIO-9039.
Is that correct? Could you upload the driver version 2.0.7 to this thread?
Message 6 of 8
(5,329 Views)
Thank you so much!!!
Smiley LOL
Message 8 of 8
(5,316 Views)
