Industrial Communications
cRIO communicating as PLC with NI-OPC-Server
Hi there,
i have the task to implement a communication between multiple cRIO's and the NI-OPC-Server. The NI-OPC-Server has to act as data handler for a complex frontend.
I tried out the NI-OPC-Server and i was successful in communicating with the NI-OPC-Server as OPC-Client in Windows using an IO-Server and Shared Variables. But the task is to do this on a cRIO. I tried to open a data socket connection from a cRIO to the NI-OPC-Server using a specific URL using "DataSocket Select URL.vi". But as long i do not activate simulation in the NI-OPC-Server i get errors on opening the data socket connection. If i do activate the simulation, which is not the solution, i can write some data without error but the Quick Client of the NI-OPC-Server sees no changes for that data tag.
I have the feeling i am not at a good way to get this working. Is there anybody having experiences with this? Is data socket a possible way at all? Is it possible at all? Do i need to implement a cRIO-OPC-driver?
Thank you.
(9,412 Views)
There's one pretty good tutorials and one webcast. Have you already study them?
Connect LabVIEW to Any PLC Using OPC (Tutorial)
Chers,
Philip
(9,372 Views)
Accepted by topic author r.tara
Hi there,
i found the solution in this article:
https://www.ni.com/en/solutions/industrial-machinery/smart-machine-control/introduction-to-opc.html
Thx for your help.
(9,364 Views)
hi
so what is the solution?
instead of pointing some URL it would be better if solution is specified point wise.
(4,663 Views)
How did you solved this isue?
Image and video hosting by TinyPic
<script type="text/javascript" async src="//cdn.youracclaim.com/assets/utilities/embed.js"></script>
(3,214 Views)
