Industrial Communications
how can I connect LabView with a PLC S7-300?
Hola
Continuo con la inquietud que plantea atras.
Consegui Industrial Automation OPC server 5.1 y he intentado configurar una coneccion S7_HMI ya que tengo el
PC adapter. Creo un nuevo objeto y configuro tal cual como esta en la pagina que recomendo Tania Losoya, el problemo es que despues de esta configuracion no se que mas hacer y si intento conectar con el PLC me sale:
Protocol Error(1): No response from PLC.
Me apena decirlo pero necesito una explicacion para bobos, que sea paso a paso de como configurar el opc server para poder comunicar mi plc con labview.
Muchas Gracias
Message 11 of 42
(19,022 Views)
Dear Berni,
I'm very interested in your experiment with PRODAVE. I've tryed to use PRODAVE drivers but I can´t do it because labwindows doesn't recognize the prototipes. Did you finally obtain any result?
Message 12 of 42
(19,951 Views)
does someone can tell me how I can connect LabView with a PLC S7-200?
Grtz DimiSmiley Wink
Message 13 of 42
(18,818 Views)
PC->LabView->Modbus->SerialPort->RS232/RS485 converter->S7-200 port 0->Standart Modbus functions in PLC program.
No OPC servers, no special interfaces, you only need to buy RS232/RS485 conveter if you dont have one.
Message 14 of 42
(18,796 Views)
Hello every body !
             Can someone tell me if  I can take  what GEDASL said for S7-200 to use it on S7-300 ?   I mean I don't have any Profibus card ,any OPC server ......... I just have a RS-232 / RS - 485 Converter and I would like to exchange datas between Labview and my S7-300 . I must have the anwser rapidly because it's for my training period .
Thank you very much and sorry for my English mistakes.
Best regards to all the members !
Message 15 of 42
(18,183 Views)
First, you need to figure out if your PLC has the HMI adapter or the PC adapter.
Here is a link that describes what to do in each situation.
http://digital.ni.com/public.nsf/websearch/E1E8217C676E56E4862569FB00734615?OpenDocument
Hope this helps.
Message 16 of 42
(18,162 Views)
hello  Rick K .
Firstly thanks for your response ( do we say response or anwser ? )
                   I finally use an USB-MPI adapter , so I'ts a PC - Adapter . But till know I can't exchange anything and any data between  my  PLC 5 s7-300 ) and my PC ( windows 2000/Xp   - Labview 7 ) . Some say that I need an  OPC Server , because Labview is an OPC client I think . Do you know something about it ?
PS :             PC ( windows xp/2000 and labview )                  -------------USB-MPI Adapter------------                   SIEMENS SIMATIC s7-300
                                                      what more ( soft or  hard ware )  do I need???????????
 helllllllllllllllllllllp !!!!!!!!!!!!!Smiley Happy
Thanks !
Message 17 of 42
(18,153 Views)
Yes you need an OPC server for that PLC setup. In addition, to make LabVIEW an OPC client you need LabVIEW DSC module.
Message 18 of 42
(18,147 Views)
thank you so much , I gonna try this and i'll tell you about it .
Best regards !
Message 19 of 42
(18,094 Views)
Hi Folks
I want to build industrial equipments like tanks/heaters/valves/motor or mixer/RTD/Level sensor in LabVIEW
i could finf tanks/RTD but i couldnt find the rest.
After building these things i want to control the action of this total process by PLC Siemens S7 200
i dont have any idea about this thing
Let me know how it can be controlled whether by using RS 232/ RS 485 or OPC server
if so is OPC server is a software...where can i download or where can i buy
If any body could help me i will be happy
Message 20 of 42
(18,007 Views)
