Industrial Communications
smc ex 600 devicenet labview communication
Hello, everyone
Hardware:
EX600-SDN1A
Device Net
EX600-DXPD
Voltage Input
EX600-AXA
Voltage Analog
SY3300-5U1
Directional Control Valves
SY3A00-5U1
NI PCI-8532 DeviceNet Card
Try Step:
User Manual “#EXxx-OMN0030.pdf” page 70, define digital output unit object attribute:
http://www.smcworld.com/upfiles/manual/e/EXxx-OMN0030.pdf
Set class id=0x6B, instance id=2, Attribute id=0x71.
Can get and set “Monitoring short circuit at output” attribute is ok, results is success.
But, this manual not define how to set or get digital output unit output state?
Now can set and get unit attribute.
I guess may be use explicit message, but I don’t know how to use, because DeviceNet message need input “service code”, and service code not exist in the user manual.
When setting follow information, use pc send message to device net then ex600 response.
Class ID
1
Instance ID
1
Attribute ID
7
Type
String
Can get string type results: ” EX600-SDN1”.
Questions:
  • How can I get analog input value through DeviceNet bus?
  • How can I get digital voltage input state through DeviceNet bus?
  • How can I set digital output through DeviceNet bus?
More information about communication protocols is needed, such as reading the voltage of the analog input, digital input, digital output.
If you have experience with DeviceNet protocol, please share with me.
(3,398 Views)
ps:
use explicit message , service code with 0x0E and 0x10, results is follow picture.
(3,391 Views)
