问个VISA Serial configuration 的问题
两个月前好好的,今天再试时出现了这样一个问题,
错误:1073807202发生于VISA Configure Serial Port(Instr).vi->xinchuan3.vi中的属性节点。
可能原因
VISA:(Hex 0xBFFF009E) A Code library required by VISA  could not be located or loaded.
问高手这是什么原因啊,以前还好好的。
(6,706 Views)
By looking at the error code, your problem is that you did not install NI-VISA. It's on the drivers CD or you can download it from the support link at the top of the page. You could have done a search of the code and found this problem discussed numerous times.
(6,700 Views)
我后来下载了,也安装了NI-VISA,可是,还是运行时出现了这样的另一种错误错误。
VISA:(Hex 0XBFFF0011)
Insufficient location information or the device or resource is not present in the system.
这又不懂了。
(6,682 Views)
Hi hms2006,
你可以试一下下面链接中的一些方法:
(6,637 Views)
谢谢,链接我也看过了,可是没有得到思路,最后我把LABVIEW的所有东西发了半个上午给全卸了,然后又把我的7.1给装了一篇,好了,又能用了,虽然VISA是3.1的。但能用就行了。
(6,627 Views)
