1073807339 error with a Hameg hm8118
I'm trying to do some simple scans with a hameg hm8118 lcr bridge, but I keep receiving the error -1073807339.
The code Im using I downloaded from NI's website http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=80634808372B577CE04400144F1EF8... .
I beliave I've gone through both http://digital.ni.com/public.nsf/allkb/E6DFA2B8D7E99F9886256C14005E82F7 and http://digital.ni.com/public.nsf/allkb/874B379E24C0A0D686256FCF007A6EA0 without generating any fruitful result (will go through them again to be sure). I have managed to send some simple commands through windows hyperterminal but when I run the labveiw code I receive the timeout error 1073807339 at the first visa read. I have tried to use an usb connection (I installed the required software for that) and a serial connection both giving me the same result. I have also tried using two different computers but with the same negative outcome. Im using labview 2012 and visa 5.3. The hm8118 is very new (purchased in the autumn of 2012) and I have updated the firmware to its latest.
I'd appreciate any help I can get, cheers.
Thank you in advance /klirfan
Message 1 of 1
(3,530 Views)
