-1073807343 ERROR NI VISA write in
NI VISA driver was working fine until I installed a Tektronix driver  .It threw the following error from then on
"1073807343 ERROR NI VISA write in"
So I uninstalled the NI VISA driver to install the new version with the bug fixes .
But I was not able to install the newer version NI VISA 14.0.1 as throws the following error
Unsupported version of NI-VISA detected
A version of NI-VISA that is not supported on this operating system has been detected. You must cancel this installation and uninstall the older version before continuing. Visit ni.com/info and enter the Info Code CleanVista for more information."
But I have uninstalled the older version already . How do I fix it ?
(6,524 Views)
I'm not totally sure what you have done. What Tek driver did you install? Why did you uninstall the previous version of NI-VISA? Typically, you just install the newer version. The old is automatically overwritten. What is your os? Did you follow the instruction about the info code? I suspect that all of this has left you with some garbage in the registry that may have to be manually cleaned up.
(6,517 Views)
I installed Tek Driver for an Oscilloscope for Labview  .I uninstalled NI VISA (older version ) , because when I tried to instal the new version , it sent an error message to uninstall older version as it is preventing the installation of new version . OS-Windows 7
(6,511 Views)
Which registry should I clean up ?
(6,507 Views)
I'm wondering if the driver installed the Tektronix VISA.  You should uninstall that before installing the latest version of NI VISA.
(6,505 Views)
Depends on the driver. A LabVIEW or IVI driver from NI won't do this. Something from Tek could have but the poster has not said exactly what he installed or what the previous version of NI-VISA was.
The registry is the Windows registry and before you start mucking around in that, do a backup.
(6,494 Views)
Cleared them manually and it works .Thanks !
(6,412 Views)
