16F877 proteus connection LabVIEW
Hello Friends, I want to with LabVIEW start a led for RS232 (serial port). I'm drawn with the program perform the printing process. How can I use VISA WRITEfeature here. Would you please help.
CSS C CODE:
#include <16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=4000000)
#use rs232 (baud=9600, xmit=pin_C6, rcv=pin_C7, parity=N, stop=1,FORCE_SW)
#use fixed_io(d_outputs=PIN_D0,PIN_D1,PIN_D2,PIN_D3)
void veri ()
char x[80];
gets(x);
if(x[0]=='A')
output_d(255);
return;
void main()
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
//output_d(0x00);
while(1)
veri();
Resized to 77% (was 1366 x 768) - Click image to enlargePosted Image
Files: http://www.uploadmb....p?id=1308177162
(4,907 Views)
Hmm, your images aren't quite loading for me, can you try to post them again, perhaps using a smaller format. Also, are you wanting to implement C code into LabVIEW or are you wanting information on using VISA Write VIs in LabVIEW? Also, what version of LabVIEW are you using?
Product Support Engineer
(4,890 Views)
Thanks for interestting. I am rened topic. Its here new link...
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/LabVIEW-and-Proteus-comminication-settings-RS...
(4,882 Views)
