34972A
I am trying to download the Agilent 34972A Driver for LabView 8.2.1 and all I get is "page not found" when I click on the download link.
(4,868 Views)
Are you referring to the links on this page? After clicking on either link and skipping that d*mn annoying popup with the survey (this is directed at NI), either link worked just fine.
Or, are you trying to download from some other page?
(4,850 Views)
Yes, That is the page I am trying to download it from. I still get page not found after about 2 min? I also tryed skipping that survey and still get page not found after about 2 min?
(4,835 Views)
Accepted by topic author Ksaw
Then the problem is likely at your end. Either your firewall is blocking ftp access (which is what those links eventually go to), or your browser is barfing.
Attached is the 8.2 version. You can still open it in newer versions - just recompile the VIs.
(4,828 Views)
Thanks for the files. That is exactly what I wanted...
(4,824 Views)
