Which run time engine is required for serial communication to build installer
Regards
Prabhakant Patil
(3,812 Views)
Accepted by topic author Prabhakant_Patil
You need NI-VISA. If  you're using a National Instruments serial port card or device then you also need NI-Serial. All software can be found in the Tech Support page.
Obviously, you will also need the Run-Time Engine for the software development environment itself as well. For example, for LabVIEW you will need the LabVIEW Run-Time.
Message Edited by smercurio_fc on 05-05-2010 08:54 AM
(3,802 Views)
