485 Loopback
If I jumper pin 2(CTS+)  & 3(RTS+) of my 485 connector, I that good enough for my loopback ?
(3,956 Views)
Accepted by NGCLarry
DB-9 RS-422, RS-485 Loopback Connection
Connect Pins:
  • 1 to 4 (Rx+ to Tx+)
  • 2 to 3 (Rx- to Tx-)
  • 6 to 9 (RTS+ to CTS+)
  • 7 to 8 (RTS- to CTS-)
Pins marked in red are the data lines, Tx and Rx, and are necessary for the loopback and BERT testing. All other pins are for modem control signal tests and are not necessary to connect unless you wish to test those signals.
DB9 RS-422 RS-485 Loopback
From Here - nice source
(3,953 Views)
Thanks.
(3,949 Views)
