64-bit Installation - not seeing gpib device in /dev
The 64-bit beta installation from http://joule.ni.com/nidu/cds/view/p/id/1000/lang/en  went flawlessly.
According to /usr/local/natinst/ni4882/gpibexplorer the device GPIB0 exists and is working, but it doesn't seem to show up in /dev/ in format that iccap is looking for.
iccap is looking for /dev/gpib0 and the closest looking device is /dev/nipalk. What am I doing wrong?
This sounds like a there is a simple solution such as a symbolic link or something.
(3,427 Views)
Hi Toulon,
Can you successfully run example programs with this card or communicate with your instrument via ibic?
Cheers,
Kelly R.
(3,395 Views)
Hi Toulon,
I also wanted to check to see if the iccap software that you are running is 32-bit or a 64-bit application?  The 488.2 driver has no 64-bit language interface, and thus is has kernel mode support only.
Cheers,
Kelly R.
(3,368 Views)
