Using ibclr with a Board Descriptor
I am currently working on rehosting some test software from QuickBASIC to C and am having some problems interpreting some of the old code, namely the use of the ibclr function. Before each call to ibwrt or ibrd, there is a call to ibclr. It seems that ibclr should be a device level command, however the parameter being used in the QB code is gpib0 (CALL IBCLR(gpib0%)). How can I emulate this when I rewrite the code in C?
(4,595 Views)
ibclr() with board level call is a "non-selected" device clear. "non selected" means that the call does not specify any listener address(es), therefore it works as like broad-cast to all the instrument on the same bus.
If you want to change the ibclr() from board-level to devcei-level, you can use the same ibclr() function but you need pass the unit descriptor of "device-level". The call works as "selected device clear" with automatic listener setting.
(4,576 Views)
Thanks for your response. So basically what the board ibclr does is the same as executing an ibclr on each device. If this is so, I can simply use ibclr on the device I am communicating with, since I am only working with one device, and this will still be equivalent to the old code. Is this correct?
(4,570 Views)
Yes it is correct, ibclr() on "board-level" and "device-level" are equivalent each other for the instrument side. Normally the instrument does not distinguish (broadcasted) Device Clear and (addressed) Selected Device Clear.
(4,544 Views)
