I have the error: -1074001648 with this comment : HP8110A Activ Deactiv Complement Output.vi, when I try to work with my HP 8110A. Where come the problem?
The HP81110A driver is also used for the HP8110, right? The functions you're refering to (HP81110A Activ Deactiv Complement Output.vi), says in in't context help that the function is avaliable with the HP81112A 3.8V/330MHz output channels. If you don't have that option, you can't use this VI.
