10-28-2012 03:05 AM
I've been working with the HP 8756A and have been having problems with it locking up after performing a read function.
After entering command 'OD' and reading all 401 points, "Data Dump" appears on the screen.From this point on I can not send any command or retrieve any data.
When I use “OI” command for identification, HP 8756A locked up again!!!
I have attached the program to call for and retrieve the data in case it is in my programming.
Thanks for any help
10-28-2012 04:09 PM
Are these driver VIs or did you write them yourself?
What does the programming manual say are command syntax?
10-29-2012 12:19 AM
NI doesn’t have any driver for it and I couldn’t find a driver that is compatible with 8756A Network analyzer. So I writed my VISA driver. I attached the operation manual of 8756A Network analyzer; there is the programming manual at 57 page of it
10-29-2012 04:18 PM
Are you able to use VISA Interactive to communicate with the instrument?
This removes the unknown of your LabVIEW VIs.
This is a very old instrument, you might also want to look into NI-488 instead of VISA.
10-30-2012 12:33 AM
I don’t know that this instrument supports VISA or not. But I did configuration setting on this instrument by “VISA write” and also I could do to force instrument to Reset.
I used “VISA open” to set VISA resource name to “GPIB1::19::INSTR”. Only, I have been having problems with it locking up after performing a read function.
So this instrument supports VISA, Is it true?
10-30-2012 01:16 PM
VISA will not be a problem. but with old old old HP-IB you need to tweak some VISA session properties (untalk and unlisten for starters)
10-31-2012 01:22 AM
I can not find terminal port on your image. I put “property node” on VI and added 6 properties, but I could not find the port which connected to “TermChar property”.
Please guide me to find it on function palette.
I attached the new Initialize.vi.
Thank you.
10-31-2012 08:08 AM
That is the Type Cast function. The point of it is to change the string character into a U8. It can be found in the Numeric->Data Manipulation palette.
10-31-2012 08:50 AM
Thank you.
That is a Snippet not an image. you can drop it on a blank block diagram and RUN it
with LabVIEW 2012
10-31-2012 10:11 AM
Hello Jeff,
Would you mind posting the snippet in an older version of LabVIEW (possibly 2009) for the benefit of others who will read this discussion forum?
