Further query.
How do you construct a command word to sent to a resource manager from a controller?
eg: MyTalk Addr 0 (Controller), MLA 1 Sub Address 0.
I've tried @!' however the writing of the last character ia not accepted by the Resource manager (BO) fails to go high following the Write to CDOR.
As a consquence the controller will not exit from the active controller mode.
I've checked the resource manager using a NI PCI controller and the primary and secondary address of the device is correct.
