A question about hardcopy GPIB remote control?
HI
    I  have implemented some basic functions.Now I want to use the remote print screen, but there are some problems:
1,use viReadToFile ,the documents are only have 4096kb
2,use viRead,Program death
    This is my VB.NET source with viReadToFile code:
Private Sub FSE_btnHDCP_Click(sender As Object, e As EventArgs) Handles FSE_btnHDCP.Click
             status = viVPrintf(vi, ":SYST:COMM:GPIB:RTER EOI" + vbCrLf, 0) '此命令更改分隔符。
        status = viVPrintf(vi, ":HCOP:DEV:LANG WMF" + vbCrLf, 0) '设置WMF格式
        status = viSetAttribute(vi, VI_ATTR_TMO_VALUE, 20000) '设置超时
        status = viVPrintf(vi, ":HCOP:DEST1 'MMEM'" + vbCrLf, 0) '
        status = viVPrintf(vi, ":MMEM:NAME 'C:\USER\DATA\FILE.WMF'" + vbCrLf, 0) '
             status = viVPrintf(vi, ":HCOP" + vbCrLf, 0) '开始
        status = viVPrintf(vi, ":MMEM:MSIS 'C’" + vbCrLf, 0) '
        status = viVPrintf(vi, ":MMEM:CDIR '\USER\DATA\'" + vbCrLf, 0) '
        status = viVPrintf(vi, ":MMEM:DATA? 'FILE.WMF'" + vbCrLf, 0) '
        status = viRead(vi, strRes, 16, retCount)
        Dim x As Integer = Val(Mid(strRes, 2, 1))
        Dim y As Integer = Val(Mid(strRes, 3, x))
        VI_txtOUT.Text = retCount
        status = viReadToFile(vi, "D:\YouName.WMF", x + y + 2, retCount) '最大4096,且写入不覆盖。
        status = viSetAttribute(vi, VI_ATTR_TMO_VALUE, 2000) '设置超时为默认2秒
    End Sub
      This is my VB.NET source with viRead code:
        Threading.Thread.Sleep(2000)
        status = viRead(vi, strRes, x + y + 2, retCount) '太长时读出为空,容易卡死
        If (status < VI_SUCCESS) Then
           MsgBox(" Failed to read from the instrument! ")
        End If
        VI_txtOUT.Text = VI_txtOUT.Text & retCount
        If strRes = “” Then
             MsgBox(“nothing”)
         Else
             strRes = Mid(strRes, x + 3, y)
             FileOpen(1, Application.StartupPath + "\YouName.WMF", OpenMode.Output) '输出文档
             Print(1, strRes)
             FileClose(1)
         End If
    End Sub
if use  viVScanf or  viVQueryf like:
status = viVScanf(vi, "%t", strRes)
status = viVQueryf(vi, ":MMEM:DATA? 'FILE.WMF'“ + vbCrLf, "%t", strRes)
Sometimes the result is empty, and sometimes the result is “#572676淄茪”
Message 1 of 20
(4,411 Views)
Agilent/Keysight instrument?  That format looks like something they use.  That # is the start of the data block.  Then the next character tells you how many characters the length is.  In this case, it tells me there are 5 characters for the length: 72676.
So what you need to do to read this is to read 2 bytes.  Remove the # and do a Val() on the second character.  Then read that many characters and do a Val() on those.  Now you read that many characters to get the actual data in the hard copy.
NOTE: Also make sure you have any termination characters turned OFF for this process.  You can turn it back on when you are done reading the data block.
Message 2 of 20
(4,384 Views)
Thank you for your reply
    In my source code you can see I had used
  to turned OFF termination characters .
   and used
   to read actual bytes in the hard copy.
   So I think the reason is not here.the reason maybe is how to use viRead or viReadToFile correctly.
PS: I use R&S FSEA30
Message 3 of 20
(4,371 Views)
I thought you have incorrect Terminator setting.
May check the IO Trace log.
YY
Message 4 of 20
(4,363 Views)
 thank you
   now i can't use  I/O Trace
  when i install NI-VISA RUNTIME , My VISA program can't connection instrument.
     when i install IO library , When running NI I/O Trace I get the error "visa32.dll is not built for NI I/O Trace.
  How to solve the problem of the conflict between“NI-VISA” and “IO library”?
Message 5 of 20
(4,345 Views)
I would like to suggest to use the latest version of IO Library and NI-VISA.
My experence, a system has 2 visa will cause a lot of unexpected results. However, this is normal in real life.
Message 6 of 20
(4,342 Views)
thank you
I'm puzzled that the function should be the same, though the source of visa32.dll is different.
this is  my Declare:
 Declare Function viOpenDefaultRM Lib "VISA32.DLL" (ByRef sesn As Integer) As Integer
 Declare Function viOpen Lib "VISA32.DLL" (ByVal sesn As Integer, ByVal viDesc As String, ByVal mode As Integer, ByVal timeout As Integer, ByRef vi As Integer) As Integer
Why can't be used in NI_VISA. NI_VISAshould be more standard
Message 7 of 20
(4,339 Views)
 A new discovery is that under condition NI-VISA mode , I can connect through TCPIP, but I can't connect through GPIB.
 PS: The linker I used is GPIB to USB.
Message 8 of 20
(4,323 Views)
the data size  is 72676kb,but only read out  4096kb.So I think the <block>size only 4096kb.
So the problem solution should be how to read <block> continuously .
 I continuous  use "viread ",but only first work.
Message 9 of 20
(4,313 Views)
hi:
     I found that I can only read the maximum of 4096kb using “viread”.So I think the max block size of instrument can only be 4096kb.
              status = viReadToFile(vi, "D:\YouName.WMF", 72676, retCount)
              the result is  retCount = 4096
   How to read block data continuously?
status = viReadToFile(vi, "D:\YouName.WMF", 4096, retCount)
Message 10 of 20
(4,318 Views)
