A question about hardcopy GPIB remote control?
     This is final data
Message 11 of 20
(2,513 Views)
@xiaochouyu wrote:
the data size  is 72676kb,but only read out  4096kb.So I think the <block>size only 4096kb.
I think that is a VISA limitation, not your instrument.  Use a loop to continuously read until you read all of the data.
Message 12 of 20
(2,504 Views)
This is a good idea, but how to read it circularly?I have tried continuous reading, but only the first one can work.
Can you tell me the specific function?
Message 13 of 20
(2,494 Views)
A related question. But it still can't solved.
如何使用VISA从串口读取多于4096个字节的数据
Message 14 of 20
(2,492 Views)
Use a read i a while loop.
Read 4096 bytes max a time.
Only the last should have the correct number of byetes left.
Message 15 of 20
(2,489 Views)
Message 16 of 20
(2,465 Views)
The question is not  loop.but is how to read correctly!
such as this code:
Dim fanal As String = ""
Do
status = viRead(vi, strRes, 4096, retCount) '太长时读出为空,容易卡死
Dim x As Integer = Val(Mid(strRes, 2, 1))
Dim y As Integer = Val(Mid(strRes, 3, x))
strRes = Mid(strRes, x + 3, y)
fanal = fanal & strRes
Loop Until (retCount < 4096)
read only 16 bytes!
if use
status = viReadToFile(vi, "D:\YouName.WMF", 4096, retCount)
the result only first viReadToFile can work!
Message 17 of 20
(2,451 Views)
can't connect “FSEA30”,may be  too old. and the source is no help.
thank you
Message 18 of 20
(2,450 Views)
You may try to download the printcapture software.
http://www.printcapture.com/equiplist.html#testequipment
the Rohde Schwarz FSEA Spectrum Analyzer is in the support model list.
Message 19 of 20
(2,446 Views)
I used to use it. it only supports NI GPIB drive. can't supports other driver such as Agilent.
Message 20 of 20
(2,443 Views)
