ACQUISITION_START_TIME
I'm trying to define ACQUISITION_START_TIME to Tektronix DPO3034 through USB interface with CVI.
I managed to install the driver and can communicate with the oscilloscope.
When I write the delay value (3.5334E-005) this is what i get from the Spy:
1.  IviScope_SetAttributeViReal64 (DPOScope, NULL, ACQUISITION_START_TIME, 3.5334E-005)
Process ID: 0x00001534         Thread ID: 0x00000874
Start Time: 17:29:42.456       Call Duration 00:00:00.015
Status: 0 (VI_SUCCESS)
That means that the right command was passed.
But... the delay in the scope comes with 0.4us resolution. That means that i can get ACQUISITION_START_TIME values of only 3.56E-005, 3.6E-005 etc.
This is what I get in the spy with GetAttribute command imeddiatley after the above SetAttribute command:
4.  IviScope_GetAttributeViReal64 (DPOScope, NULL, ACQUISITION_START_TIME, 3.56E-005)
Start Time: 17:34:11.995       Call Duration 00:00:00.016
(The actual delay on the scope screen is also 3.56E-005...)
Thank you for your assistent!
(5,521 Views)
Does the scope support the delays you want?  Do you know that the scope can be programed by other means to accept that value?
(5,493 Views)
Yes, the scope supports the delays I want when I define them manualy or with stand alone program based on LabView (don't have access to the code...)
Just to mention that the CVI program does what I need on 3 other scope models.
(5,482 Views)
Can you compare the NI-SPY logs for the what is sent using the LabVIEW (successful) and CVI (unsuccessful) drivers?  are the two drivers writing to the same atributes?
I also wonder if there is precision setting for the delay that must be set prior to specifying that delay.  You may want to look several commands back in the NI-SPY logs to try and find such a precision setting.  The idea of a precision setting is pure speculation on my part.
just to confirm; The labview driver for DPO3034 functions well but the C driver for the same instrument is demonstrating the undesireable behaviour?
As a work around you could call the labview code from C.
(5,463 Views)
Accepted by GE-HCS
This was a rounding to 400ns in the driver from NI that came after a comment that this is due to change in the firmware. I chaged the rounding back to 4ns and everything is fine.
(5,404 Views)
