AT-GPIB/TNT board driver with linux kernel 2.2.16
I have installed AT-GPIB/TNT board to my linux computer. I downloaded the driver 0.5.1 from ni web site, installed with no problem.
First I used Window98 OS to test my hardware setup. My GPIB board is connect HP E3632A DC Power supply. I can use window version's ibic to run ibfind, ibdev, ibwrt, ibrd. Then I booted to linux, load the drive. But when I run ibwrt, give "EBUS" error. I used small test program to verify that I would get the same error. But I couldn't get it from Windows.
Where is my problem? inside the driver? or linux driver setup?
Thank you in advance
Allyson
(3,485 Views)
Version 0.6 of the BETA driver is available at:
http://www.ni.com/linux
See if this new release gives you better performance
Ryan Mosley
(3,485 Views)
