Access ni4882.dll with Qt and MinGW
Hi A.R.M:
                Do you creat libgpib.a file vi MarkoSat's method? Could you shere to me. I'm faild to creat the libgpib.a file. I am using pexpors(0.46).
Thanks.
Mitchell
Message 11 of 19
(4,741 Views)
I did get it to work after a while, A zip file with all the stuff I used as well as the resulting .a file is attached.  One of my lab mates had trouble with it on a different computer, but switched over to the MSCPP version of Qt and said everything worked right away.  Cheers -A
Message 12 of 19
(4,734 Views)
Hi A.R.M:
               Thank you for sharing.
Mitchell
Message 13 of 19
(4,731 Views)
Hi A.R.M:
                I try to use the libgpib.a, but something wrong. The fail message shwo as below:
An exception was triggered:
Exception at 0x7c9873be, code: 0xc0000139: DLL entry point not found, flags=0x0.
During startup program exited with code 0xc0000139.
below is my code:
.pro
win32:CONFIG(release, debug|release): LIBS += -L$$PWD/../build-GPIBTest-Desktop_Qt_5_3_MinGW_32bit-Debug/release/ -lgpib
else:win32:CONFIG(debug, debug|release): LIBS += -L$$PWD/../build-GPIBTest-Desktop_Qt_5_3_MinGW_32bit-Debug/debug/ -lgpib
else:unix: LIBS += -L$$PWD/../build-GPIBTest-Desktop_Qt_5_3_MinGW_32bit-Debug/ -lgpib
INCLUDEPATH += $$PWD/../build-GPIBTest-Desktop_Qt_5_3_MinGW_32bit-Debug/debug
DEPENDPATH += $$PWD/../build-GPIBTest-Desktop_Qt_5_3_MinGW_32bit-Debug/debug
.cpp file
int hDev;
if(hDev=ibdev(0,17,0,T10s,1,10)<0)
QMessageBox::warning(0,"","Unable to get a vaild description of Power supply");
else
QMessageBox::warning(0,"","Get a vaild description of Power supply");
Do you have encountered the same problem?
Mitchell
Message 14 of 19
(4,726 Views)
My project file is below, the important stuff is at the end:
QT       += core gui webkit
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets printsupport
TARGET = UtilSweep
TEMPLATE = app
SOURCES += main.cpp\
        utilsweep.cpp \
    agilentsweeper.cpp \
    qcustomplot.cpp \
    lockin7265.cpp \
    keithley2k.cpp \
    lockin7270.cpp \
    daqlakeshoremag.cpp \
    utilsweepdata.cpp
HEADERS  += utilsweep.h \
    agilentsweeper.h \
    qcustomplot.h \
    keithley2k.h \
    lockin7265.h \
    lockin7270.h \
    ni488.h \
    NIDAQmx.h \
    daqlakeshoremag.h \
    utilsweepdata.h
FORMS    += utilsweep.ui \
    agilentsweeper.ui
win32: LIBS += -L$$PWD/ -lNIDAQmx
LIBS += $$PWD/libgpib.a
 where there is a copy of the GPIB files in the same directory. You have windows.h included first in the source right?  -A
Message 15 of 19
(4,713 Views)
Hi A.R.M:
               Thanks for your reply. I have success to use the lib. I think that  I put the libgpib.a to the debug folder cuase this problem. I put the libgpib to the same folder then solve this problem. Thanks for your help.
Mitchell
Message 16 of 19
(4,693 Views)
Hi A.R.M,
after a long time, your post and your zip file were still useful for me and I just wanted to say: Thank you!
Message 17 of 19
(3,645 Views)
Glad to hear it!  Made my morning.  -A
Message 18 of 19
(3,637 Views)
Hi Marko,
Thanks for step by step description.
I run the commands in CMD. Unfortunately, my generated libgpib.a after running "dlltool -k -D gpib-32.dll -d gpib.def -l libgpib.a" command is 0 kB.
In addition, after running the command "pexports -h ni488.h gpib-32.dll > gpib.def", following error is generated:
'gcc' is not recognized as an internal or external command operable program or batch file.
how can i solve the problems?
thanks a lot.
Message 19 of 19
(3,124 Views)
