After installation of Visa runtime my mouse is moving with COM data
I'm sorry, I don't know anything about Labview I'm just using prepared GUIs.
After installation of the Visa540 runtime my mouse is moving everytime I get data from the COM1. How can I switch this off?
(4,658 Views)
Accepted by LippertC
Are you using a USB-Serial adapter?  Was the device sending data during the computer's boot up?  Was the device sending data while the USB adapter was being plugged in?
This is likely a Windows issue.  If you connect up a serial device (USB-Serial adapter anytime or a build-in/PCI serial port at bootup) and the device is sending data, then Windows will think that the serial device is a mouse.
(4,649 Views)
sometimes it can be very easy 🙂
(4,642 Views)
