Agilent 33220 USB Application and Runtime Engine
Hello
Ich used the example codes from NI for the Agilent 33220 function generator "Getting Started.vi". It works fine on my computer with LabView 7.1. But when I run it on another computer without LabView installed, it wont work. I have installled the iolibs suite 14 from Agilent and the drivers for vxipnp and ivicom on the other computer. I also generate an Installer.
I am not really sure with options I have to choose for the Installler. Do I need the Active-X server? What are the correct settings in the installer options or settings? Or is there other important settings I forgot about?
Cheers
Marcus
(4,632 Views)
I forgot to mention that I get the following error message when I start the exe on the other computer after installing it.
Error 1073807343 occurs at VISA: opening ag33xxx - initalize.vi -> ag33xxx - getting started.vi
possible errors: VISA (HEX: BFFF0011) not enough information about memory or device or resource not available in system.
I am using the german version of LabView so the text might be a bit different than on the english version.
Marcus
(4,627 Views)
The error code 0xBFFF0011 is a VISA error - VI_ERROR_RSRC_NFOUND.  I believe it is a VISA problem.  Does the target PC insall Agilent IO Libs Suite 14 alone, without installing NI-VISA?  Multiple VISA versions from different vendors can't be installed at a time, otherwise similar errors may occur.  Try to operate the VISA Assistant utility from Agilent that comes with the IO Libs Suite 14, such as sending a simple "*IDN?\n" query on the real VISA address such as "GPIB0::<address>::INSTR".
Also if your app passes a Logical Name for the IVI driver's "Initialize.vi" call, instead of passing a real VISA address, you must properly configure the Logical Name, so that it can be redirected to a real VISA address through the Driver Session, Software Module, and Hardware Asset configuration.
このメッセージは 08-31-2005 01:16 AMに Makoto が編集しています。
(4,616 Views)
Hi
It was a driver problem. I reinstalled the io libs and then it worked.
After deinstallation of my exe from the target computer it seems to me that it deletes some important files. When I installed the application again the porblems occurs again. A new installation (repair) of the io libs works fine.
Marcus
(4,603 Views)
