Agilent 34401 Read Multiple Measurements
Hello all!
I'm looking to acquire multiple samples(multimeter to take up to 50,000 readings) at the same time. The multimeter is connected through an GPIB-USB inteerface to PC. I have below an VI that makes this, but onl;y for one sample. I've modified the VI (in the constant string SAMP:COUN X, where x=no. of samples) but no succes. If you have an idea please give an advise.
Thanks!
(4,574 Views)
Accepted by topic author Samoth
I made it but for 20 samples/sec. I wish to acquire 10000 samples/sec. The application is try.vi
(4,561 Views)
Sorry,I forgot the application.
(4,549 Views)
I don't quite understand what you are doing and what the problem is. What happens when you run the example for multiple measurements? it's there in the example finder (Hardware Input and Output>Instrument Drivers>LabVIEW Plug and Play>Agilent 34401 Read Multiple Measurements.vi.
(4,539 Views)
It's OK now. Sorry for mode of expression.
(4,517 Views)
