Agilent E3633A DC Power Supply
Hi All,
Hope someone can offer some advice here. I got a Agilent E3633A DC
Power supply second hand from overseas.
I swapped the line voltage to 230 for my country. The fuse in it
currently is 6.3a 250v (reccomnded for 110v operation) but for NZ a
3.15a 250v fuse is reccomended.
When I power it up I get one beep and the display self tests for a
second before going blank and none of the buttons do anything.
Sounds like a controller issue of some sort?
Yes, I know I need to change the fuse, but with no load attached, I
cant imaging it being able to detect it has the wrong fuse intstalled
and should power on ok?
Anyone have any other ideas?
Cheers
-Al
(4,053 Views)
Did you ever figure this out?
(2,969 Views)
On some instrument you need to move the fuse over to select the right line voltage.  We had a similar problem and found the fuse was in a little holder marker 110V and if you turned it over there was a 220V slot.  Moving the fuse over and replacing solved the issue.  Not sure about this one though, I'd consult the manual.
(2,960 Views)
