Keithley 2000 data logging script
Hi all,
I've inherited a script to log resistance measurements from a Keithley 2000 multimeter and have been trying to set it up on a new computer. I've tried both drivers I was able to find online (http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E960B659CE034080020E748... and http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=248) and tried it in Labview 2017 and 2016.
I'm new to Labview (and coding in general) and have found the online training courses but would like, if possible, a quick fix to start taking measurements again. Is anyone able to get it to run?
Many thanks in advance!
(3,688 Views)
Pretty hard to help when you don't describe a problem.
Describe what's not working, and what you expect.  Describe the error message you get, error logs, and any other pertinent info that might be helpful.
(3,670 Views)
Looks like it was made with this 2004 LabVIEW driver which you can't download from those links.  You could update or use the older version attached.
(3,664 Views)
