Instrument not displaying in MAX
Hi
I work for a lab instruments company which uses a USB to IEEE converter.  Normally in MAX, we see the interface and then an instrument aligned underneath it.  In this one customer's case, it does not .  The software appears to be working because our software sees and controls it. This happens both for a normal domain user and also an administrator.
Any thoughts on what to check ?
John Walsh
(3,198 Views)
If you did connected the instrument correctly on GPIB bus, and the address is setted well.
Do you try "Scan for instruments"?
(3,169 Views)
Hi
Yes.  Scan for Instruments did not update the display as expected.
John
(3,158 Views)
Disconnect all instruments from the bus then begin attaching one at a time.  After a new instrument is attached, try the Scan for Instruments.  Some GPIB instruments (failing) can lock the bus causing a POLL function to fail.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,155 Views)
Hi
Thanks for the reply.  I should have included more detail.  There is a single Interface (interface 0) with a single device connected directly to the converter.  Higher level functions within the software that use the NI driver function as expected - for example, numerical readbacks from the instrument.  It just do not show as expected in the MAX application.
John
(3,153 Views)
