Agilent E4438C ALC BW (10kHz) Control
I want to set the amplitude for Agilent E4438C Signal Generator, here I need to set "ALC BW = 10kHz", does anyone know how to do this? I tried the functions of sub-VIs in instr.lib, but failed.
Many thanks for your help and time!
Happy holidays ~ ~ ~
Jeanne
(3,771 Views)
Hello Jeanne,
I will attempt to answer your question based upon the information you posted.
The Config Amplitude.vi will set up the amplitude for your generator and the Config ALC Search Span.vi will set up the bandwidth.
Are you trying to generate a signal with a certain amplitude and bandwidth?
Please let us know if this helps.
Christian A
(3,747 Views)
