Agilent Logic Analyser 16700
Hi
I am using Intuilink Installer (Agilent16700Install) for Agilent Logic Analyser 16702B. I need to remotely read the values from LA. If i am trying to run it once & read the data it works fine, but when i am trying to read the labels when the LA is in Run Mode then it gives a error message "Cannot query the selected module for data or info while running"
I have connected the code for the same & also explained the problem in block diagram itself Help Please !!!!!!!!!
Rajan
Thanks & Regards,
Rajan
(3,360 Views)
Intuitlink is a program from Agilent and I'm not sure how much help you can get about it here.
You have no attachment.
(3,352 Views)
