Hi
I am using Intuilink Installer (Agilent16700Install) for Agilent Logic Analyser 16702B. I need to remotely read the values from LA. If i am trying to run it once & read the data it works fine, but when i am trying to read the labels when the LA is in Run Mode then it gives a error message "Cannot query the selected module for data or info while running"
I have connected the code for the same & also explained the problem in block diagram itself Help Please !!!!!!!!!
Rajan
Thanks & Regards,
Rajan
