Agilent PNA N5224A
I need about 60 secs.
Message 11 of 25
(3,587 Views)
balan12,
where did you get the instrument drivers from? I have a N5227A PNA, and I could not find Labview drivers anywhere. Agilent technical support was of little help.
Message 12 of 25
(3,559 Views)
I don't have the driver. I am using VISA Read and Write and communicating via the LAN port.
The error, " Visa Read timing out" which I had is due to I am sending write command and expecting to read the response from the analyzer.
Message 13 of 25
(3,550 Views)
When I programmed the N5224A over LAN, I used COM which is actually more flexible. Some commands are not available in SCPI.
http://na.tm.agilent.com/pna/help/latest/Programming/Learning_about_COM/COM_versus_SCPI.htm
However, if you want to do SCPI over LAN, then read http://na.tm.agilent.com/pna/help/latest/Programming/COM_Reference/Objects/SCPIStringParser_Object.h...
Message 14 of 25
(3,541 Views)
Thanks. I'm still getting used to it. Where can I find a list of all the necessary commands required for communicating with the N533xA series using VISA?
Message 15 of 25
(3,510 Views)
That was N522xA, not 533x.
Message 16 of 25
(3,508 Views)
I get a timeout error for any operation other than *IDN? . My timeout is set to 20 seconds. Help needed.
Message 17 of 25
(3,467 Views)
Hijacking someone else's thread is not a good thing.
Stick to your own post http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/SCPI-Command-to-make-S-Param-measurement-Agil...
Message 18 of 25
(3,458 Views)
Make sure you are not trying to read something that is not there. Example writing *CLS\n" and then trying to read will give you "timeout error".
Message 19 of 25
(3,445 Views)
I am able to display an S parameter measurement on the PNA window using the following commands.
CALC1:PAR:DEF:EXT 'measurement1', S11
DISP:WIND1:STAT ON
DISP:WIND1:TRAC1:FEED 'measurement1'
CALC1:PAR:SEL 'measurement1'
CALC1:MARK:STAT ON
However, when I use the CALC:DATA:SNP:PORT:SAVE command to write SNP data to a file immediately after the above commands, it doesn't save to file. Any help/suggestions?
Thanks.
Message 20 of 25
(3,379 Views)
