Agilent U2356A Configuration
Hello all,
I'm having trouble getting my Agilent U2356A configured correctly for my application.  My task is simple: measured 10 samples at 100 Hz on channel 101.  I want differential mode, unipolar (0-5V).  I have verifed my connections using the Agilent measurement tool, but when I try to acquire data with LabVIEW I don't get the correct voltage.
Here are the parameters that I am using:
ROUT:SCAN (@101)
ROUT:CHAN:POL UNIP, (@101)
ROUT:CHAN:RANG 5, (@101)
ROUT:CHAN:STYP DIFF, (@101)
ACQ:POIN 10
ACQ:SRAT 100
Any suggestions?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,808 Views)
How does the voltage you are reading differ from the expected voltage?
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(3,782 Views)
Accepted by vt92
I talked to an Agilent support person and we resolved the problem.  I was "unflattening" as U16 instead of I16, which threw off the conversion.
(3,772 Views)
