Agilent U2356A Configuration
Hello all,
I'm having trouble getting my Agilent U2356A configured correctly for my application.  My task is simple: measured 10 samples at 100 Hz on channel 101.  I want differential mode, unipolar (0-5V).  I have verifed my connections using the Agilent measurement tool, but when I try to acquire data with LabVIEW I don't get the correct voltage.
Here are the parameters that I am using:
ROUT:SCAN (@101)
ROUT:CHAN:POL UNIP, (@101)
ROUT:CHAN:RANG 5, (@101)
ROUT:CHAN:STYP DIFF, (@101)
ACQ:POIN 10
ACQ:SRAT 100
Any suggestions?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,809 Views)
How does the voltage you are reading differ from the expected voltage?
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(3,783 Views)
Accepted by topic author vt92
I talked to an Agilent support person and we resolved the problem.  I was "unflattening" as U16 instead of I16, which threw off the conversion.
(3,773 Views)
