An Hardware Question
 I'm an new developer in creation of test and automation systems and i need a help to solve one problem.There's an method or way to retrieve the "type of an instrument" (For example,VISA command to detect an new instrument connected as a Power Supply or an Eletronic Load without making any alias) or source of a "Unique Identification" can determine by the response of an command in Labview of what kind of device my machine is connected to?
Sorry for bad english. I'm an Brazilian :c
(3,548 Views)
Accepted by uChiron
There is some examples that you can use in your application. Follow someones:
Determine the Current VISA Version Programmatically
https://decibel.ni.com/content/docs/DOC-3721
Programmatically Determine What VISA, DAQ, or MI Cards are in a Chassis
https://decibel.ni.com/content/docs/DOC-3723
Programmatically Opening VISA Resources Based on Instrument Name
https://decibel.ni.com/content/docs/DOC-6439
Find PXI Slot number using VISA
https://decibel.ni.com/content/docs/DOC-16086
VISA: List all VISA Devices
https://decibel.ni.com/content/docs/DOC-2175
Regards.
Erick Yamamoto
Application Engineer
National Instruments Brazil
Visite a nossa comunidade em PORTUGUÊS!!!
Certified-LabVIEW-Associate-Dev Smiley face
(3,509 Views)
