Analog voltage control
I am looking for different options to control an electronic valve. The control input is electronic voltage signal between 0-10 Volts and I need precision of 0.1 Volts. Is it possible to get a digital output from the computer (like USB) and convert to an analog signal within the corresponding range via using commercially available NI products?
Best,
Sertan.
(3,561 Views)
Just look at the various Multifunction DAQ products.
(3,557 Views)
Accepted by serkut17
Hi Sertan,
If you're looking for a specific product line, it looks like our M-series products will provide your desired functionality:  USB, +/-10V analog output, and higher precision than you need.  Have a good day!
Bus-Powered M Series Multifunction DAQ for USB - 16-Bit, up to 400 kS/s, up to 32 Analog Inputs, Iso...
(3,544 Views)
Hi there,
Thanks a lot for the reply, the NI devices that you sent me were not feasible for right now. However, we are planning to buy in the future but for now we are gonna find another solution temporarily.
Best,
Sertan.
(3,525 Views)
