Any WIBIC command leads to memory access error
Input any command in WIBIC leads to violation memory access error in USER.EXE. Compatibility realise DLL's for win32 are installed.
(3,515 Views)
Do you have the newest version of NI-488 installed? Check http://www.ni.com/support/gpib/versions.htm for the newest version of the driver that supports your hardware.
Best Regards,
Aaron K.
Application Engineer
(3,515 Views)
