Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Any WIBIC command leads to memory access error
kembrick
Member
05-05-2003
04:54 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Input any command in WIBIC leads to violation memory access error in USER.EXE. Compatibility realise DLL's for win32 are installed.
0
Kudos
Message
1
of 2
(3,519 Views)
Reply
Re: Any WIBIC command leads to memory access error
AaronK
Active Participant
05-06-2003
01:25 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Do you have the newest version of NI-488 installed? Check http://www.ni.com/support/gpib/versions.htm for the newest version of the driver that supports your hardware.
Best Regards,
Aaron K.
Application Engineer
Kudo
Message
2
of 2
(3,519 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
