Anyone got a LabVIEW driver using VISA for Keithley 6220 current source?
hi there!
i need a pure LabVIEW driver for the Keithley 6220 Current Source using VISA.
thanks in advance!
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 1 of 14
(7,528 Views)
hi chrisger,
for that I think you should contact Keithley if anything like this exists.
tried to search for it, but their page appears to be down for the moment.
greets!
Message 2 of 14
(7,513 Views)
hi there
yes, they supply a LabVIEW driver, but that calls IVI via a Keithley - DLL, so my app has to deliver several additional dlls and other files. They don't supply a pure LabVIEW VISA - driver....
thx anyway and best regards
chris
Best regards
chris
Message 3 of 14
(7,508 Views)
NI is interested in developing a native LabVIEW Plug and Play driver for this instrument and we are working with Keithley to secure an instrument loan. I can't provide any details of when the driver will be available until I get the instrument in the possession of a developer.
Jason Hobbs
Instrument Drivers
Message 4 of 14
(7,505 Views)
Hi Jason,
i created a LV interface using VISA suitable for my application (need just some DC - operations).
thx and best regards
chris
Best regards
chris
Message 5 of 14
(7,488 Views)
hi
I am looking myself for a Visa LabView driver for the same instrument (Keithley 6220). Has NI developped such a driver ?
thanks
Message 6 of 14
(7,142 Views)
hello chrisger
can you share your vi with Visa for Keithley 6220 please ? What I need is just some simple DC functions : set curr, compliance voltage and FILT on/off...
thanks in advance (that would help me a lot to avoid all the instructions CURR... etc)
regards
Message 7 of 14
(7,130 Views)
Hey nitad,
NI has actually developed the driver for the Keitley 6220. You can get it through http://sine.ni.com/idnetwork/. Search for 6220 and it should be the first one on the list. You will need the IVI compliance Package version 2.3, which can also be found. That should all be linked on the page
Hope this helps
Can Wong
Message 8 of 14
(7,114 Views)
Thanks for the answer. I will take a look
regards
Message 9 of 14
(7,103 Views)
Hello Can W
I have downloaded mentioned driver (Keithley 6221) , but all I have found is the set of files, which are related to the .llb file (as replaied above). Is there any pure LabVIEW driver available (like for example for 2400), cause I would need to change some options inside several subVIs and I cannot, because all the subVIs are have only inputs and reference to the library inside. Or maybe someone has already made appropriate library? I need to use rather complex operations (Diff conuctance, custom sweep mode etc).
Thanks in advance
Wito
Message 10 of 14
(6,594 Views)
