Arduino Duemilanove atmega32 connection failure
Good day
I am using labview to control a push-pull solenoid via Arduino. i get a connection error that says:
 Error 5002 occured at Ini.vi. Unable to establish connection with Arduino.  Please ensure that you have selected the correct COM port and that you have flashed the Arduino with the correct firmware.
Any idea how i can overcome this please?
Nicod
(3,332 Views)
Hello nicod:
Have you already saw the suggestions on this National Instruments  Knowledge Base article:
Why Do I Get Error 5002 When Using the LabVIEW Interface for Arduino?
(3,305 Views)
Hi
I tried all the suggestions thank you, but still not working
so i tried my code on a different and PC and it works there, so something is wrong with my windows settings for it not to detect Arduino
Kind Regards
(3,261 Views)
