Using NI OPC server with other hardware
HI,
     I am using an AIS Mitsubishi plc for a project that I am doing at the moment. As this is an old plc can i connect to labview with this plc by using opc server.
Thank you.
(2,851 Views)
Hi Smchale,
You can connect via OPC to almost any PLC. There is a list of supported devices here and info on connecting here.
Let us know if this helps.
Kind regards,
Riley Ilieva
(2,832 Views)
