Sending data from arduino uno to labview
Hello, i have a GY 85 sensor that includes a gyro, accelerometer and compass, i am reading the data on arduino and i want to send it on labview. I am using the vi attached below, i feel like i did something wrong and i dont want to store the data in a file, i want to use the values in the same vi (real time).
i would really appreciate an answer!!!
P.S: should i send the data to labview or Myrio?
(4,413 Views)
Hi
I don't see any code addressing the arduino, where is it?
greetings from the Netherlands
(4,401 Views)
this is the arduino code. Sorry i'm a newbie in serial communication.
(4,393 Views)
Hi
From the code it looks like the Arduino is indeed sending the data to the serial line.
Also I don't know why you are writing about the MyRIO. Do you have a MyRIO and are you using it in any way? The project is doing nothing at all.
I suspect that the express vi you call is also a MyRIO vi.
But maybe I'm wrong.
Can you send it also?
(4,391 Views)
This vi is getting the data from the arduino, the buffer indicator shows the acquired data, but in that way i can't use them. Once i'm able to use the data ill copy the code to the original vi ( it won't be helpful here), so in short i want to use the data acquired form the arduino in the code
(4,390 Views)
where did you find this vi? Can you post it so I can look at it?
(4,351 Views)
