Are appliction notes available for the TNT4882 ASIC.
I am designing hardware that will use the TNT4882, and I have 2 questions: what is recommended for bypass capacitors on Vdd, and is a ground plane recommended for the PCB.
(3,023 Views)
Hello-
8 - 0.1uF bypass capacitors are used on our AT-GPIB/TNT boards. A ground plane is recommended for the TNT4882.
Randy Solomonson
Application Engineer
(3,023 Views)
