Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Are appliction notes available for the TNT4882 ASIC.
jdklaus
Member
02-25-2002
02:18 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am designing hardware that will use the TNT4882, and I have 2 questions: what is recommended for bypass capacitors on Vdd, and is a ground plane recommended for the PCB.
0
Kudos
Message
1
of 2
(3,012 Views)
Reply
Re: Are appliction notes available for the TNT4882 ASIC.
Randy Solomonson
Active Participant
02-26-2002
11:50 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello-
8 - 0.1uF bypass capacitors are used on our AT-GPIB/TNT boards. A ground plane is recommended for the TNT4882.
Randy Solomonson
Application Engineer
Kudos
Message
2
of 2
(3,012 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
