Array 3645A Power Supply With LabVIEW Demo
Hi Tommy,
Is it a constant value at 128 or 384? If so, my best guess would still be the ground current loop.
Josh Y.
Message 21 of 32
(4,014 Views)
Hi Josh
I had put a Configure Power supply Parameters.vi in the while loop so I could adjust the voltage, I added after Error Query.vi When I moved it to before Error Query.vi, it worked as it shouldSmiley Happy
Message 22 of 32
(4,007 Views)
Hi Tommy,
Good fix! Thanks for letting us know not only that the issue is solved but also how you solved it.
Josh Y.
Message 23 of 32
(3,960 Views)
Does someone have this vi in this form?  I would like to know what the front panel looks like. Thanks. Jeff
Message 24 of 32
(3,714 Views)
What VI are you talking about? The previous comes from the driver example. Help> Find Instrument Drivers.
Message 25 of 32
(3,703 Views)
Message 26 of 32
(3,689 Views)
Yes, I installed the drivers. No, NONE of them work. YES, I am communicating with the instrument.  In this image, is this .vi available? What would really, really, really be handy, and is rarely done, is a sample .vi which sets a voltage, reads a current, or vice versa.  Very simple. Does anyone have this ? Does National Instruments have this?  What is the .vi shown in this image?  Thanks. Jeff  http://forums.ni.com/ni/attachments/ni/140/52437/3/Array%203646A%20functioning.png
Message 27 of 32
(3,664 Views)
Every project style driver includes an example. Help> Find Examples. The example for this driver is listed in the 'Start Using Instrument Driver' image above.
Message 28 of 32
(3,658 Views)
Hi Jeff
Yes, I installed the drivers. No, NONE of them work. YES, I am communicating with the instrument.  In this image, is this .vi available? This is the sample shown in the 'Start Using Instrument Driver' image above. What would really, really, really be handy, and is rarely done, is a sample .vi which sets a voltage, reads a current, or vice versa.  Very simple. Does anyone have this ? Does National Instruments have this?  What is the .vi shown in this image? This is the same, please read my answer from 03-22-2012 05:06 AM  Thanks. Jeff  http://forums.ni.com/ni/attachments/ni/140/52437/3/Array%203646A%20functioning.png
Message 29 of 32
(3,643 Views)
Hello everyone!
I ve got problem with comunication. Is it possible to communicate without 3311 adapter? I ve got just device and RS232->USB cable. Examples from http://sine.ni.com dosn't work and I do not know what I should change.
Greetings!
Message 30 of 32
(3,463 Views)
